Enphase Failures
    • 5231
    nice... but why limit yourself to binary? With the bypass diodes in most panels, you
    have quaternary states to work with.
    Now we are down to potholders and complex test routines? Does it matter, can we use a panel with a section being
    bypassed? Actually I have considered that myself; have 2 marginal panels that could serve as one good one if the
    weak columns were shorted or wired out. Haven't found the ideal app for them yet. Bruce Roe
      .....When I bought my 62, an old time mechanic told me to get some appropriate tools to work
      on it. He was right, too bad they never taught that in school. Here is my 79 resting on my
      most expensive "car" tool. Bruce Roe
      The lift tool or the shop tool ? Both are nice.
        • 5231
        Thanks, I learned a couple things about tools. They generally pay for themselves the first time you use them.
        If a job isn't going well, its time to step back and see if you need to use a different approach with better tools.
        After I started doing my own transmissions, it was time to get a car lift. That new lift was less than $4K,
        installed it myself. A couple trans jobs and its paid for; meantime all manor of stuff is so much easier and
        cleaner. And it extends the years into retirement I can continue to do heavy repairs,. The building used to
        be for motor home storage. Bruce Roe
        • AzRoute66
          • Jul 2017
          • 446
          I wonder how many individually optimized systems have been mis-mapped from day 1, and have never been discovered as such.
          • max2k
            • 819
            or even more interesting- what percentage was mapped correctly? There was not much incentive to ensure what was where as long as all of them worked and most of them did at the beginning.
            • ButchDeal
              • 3802
              It is usually pretty easy to tell if they are done wrong by playing through the day and watching start up and shut down order.
              • AzRoute66
                • Jul 2017
                • 446
                For real??? Wow. That would have lost me a bar bet. I mean, they are all in the same plane, and quite some distance from the sun.
                • ButchDeal
                  • 3802
                  Sure from the sun but the shadows are cast by local objects including the horizon, trees, even the module to the east.
                  Once you have seen a few solaredge sites in play back much less a few thousand of them it is pretty simple and intuitive.
                  i have gotten diagrams from installers that are backwards or not clear and it is easy for me to fix. Most installers on their own would just leave the layout completely off and not bother putting them in wrong.
