Is there a way for a customer to update the firmware of a solaredge inverter? Do the units auto-update? Where can you check was is the latest firmware version available?
Solaredge inverter firmware update
Here is what I can see through the portal... go to the layout, click on the inverter, click on the "i" to show more device information.
Below is what shows up for my new 7.6kW inverter and my 2015 3kW inverter.
Last edited by sensij; 06-21-2017, 01:14 AM.CS6P-260P/SE3000 - http://tiny.cc/ed5ozx -
I can see similar information in mine but how do I know if it has the latest firmware?https://pvoutput.org/list.jsp?userid=59404Comment
Looks like we have the same DSP2 version, while i have a higher DSP1 version and you have a higher CPU version. On that basis, it doesn't look like they are remotely brought to the same version routinely, and it might be lot specific. I'm not worried about it... If the system is functioning, probably safe to assume the firmware is fine.
CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
My FW was recently updated due to some inverter problems (remote push). I don't think there is a way for you to force the update (I looked around but didn't find a way without getting a download of the new version and putting it on an SD card, and I couldn't find anywhere to download an image)
This is what my inverter is sitting at now. The only thing I know updated was the CPU Version. It was 3.1968 before the update
I did find this, but it is for StorEdge. I couldn't find a similar page for a regular inverter
Ok, so yours looks the same as macaddict 's, except that his DSP1 looks newer. That sort of says the firmware is not model specific, since you have a 6k and he (and I) have a 7.6k. My two year old 3k inverter clearly has older firmware, so they probably don't mess with it unless a problem needs to be fixed.
Here is mine. I will have to see in the morning if the firmware updates that solaredge edge pushes through the night works but my 7600 hd wave inverter was not working and a red fault light came on and the screen had a HW error and the error code was 18xB7Last edited by Afrmthabay; 04-05-2018, 02:06 AM.Comment
