Hi. We're in the process of building a large house and will have about 20KW of solar panels on top of the house and the detached garage. We live in PGE territory so energy prices are pretty high so I am trying to make sure we stay in Band 1 for usage. The utility power where the house is can also be somewhat flaky, and do I am planning on generator backup. I plan to use the new TOU rates that PGE has gone to, with more restricted times.
What I'd like to do is have a system that can operate in two modes:
1) When utility power is on, to charge a set of batteries (powercells or others) through the morning and afternoon, and then when peak hour kicks in, push the stored power back to the grid for maximum economic value through that window, and then go back to utility power through the evening.
2) When utility power fails, I'd like to have the solar charge the batteries, support the house demand as needed, and then when the batteries hit a low charge point, have the generator kick in to charge the batteries at roughly the solar panels normal rate, and then have the generator go back to standby. This avoid running the generator continuously and at low demand when it's inefficient, and still allows solar to charge the batteries and use solar power during an extended outage.
Is it possible to design a solar power system that can do both of these things?
Sorry if I'm missing something obvious, I have a PV system at our current house, but there are no batteries or gensets involved there.
Thx
mike
Thx
mike
