In considering proposals for a 4.3kW system using either 96-cell modules rated 69.7 Voc or 60-cell modules rated 38.9 Voc. Cost of 96-cell module is higher, of course, but one of the benefits of the higher cell count, according to the mfr, is that its higher voltage output will get it within MPPT range of the optimizer/micro inverter earlier and later in the day, thus producing more power overall and, importantly, more power late in the day when net metering is credited at peak rates.
Is there some source where I can find an hourly irradiance curve for Southern California?
I assume that cell output is probably linear with respect to irradiance, but is there a minimum irradiance level below which internal impedance overcomes voltage generated?
Will that 19%+ module efficiency rating be lineal across all irradiance levels?
