some quality transformer inverters are now available at a reduced price, typically for about half of what a transformerless one costs. so if i could buy a transformer inverter for about $750 vs. a transformerless one for $1500, is it worth saving the $?
transformer inverter vs. transformerless inverter - worth the savings?
You'll have to add additional external equipment to meet current codes. Not worth the savings IMO. -
What electrical code? This is not meant to be insult but if you do not know the protections that might be missing from said old stock inverters being dumped into the market, you probably shouldn't be using.Comment
it includes a dc disconnect that disconnects under load (if needed) and it has AFCI. so it doesn't really seem to be lacking much. i started off asking about a choice between two inverters one with transformer, and one without. you said to avoid the transformer inverter. fair enough. so, what external equipment might be missing? and no, i'm not familiar with a transformer inverter.Comment
Transformerless are not near as robust and good as ole Boat Anchor Transformers. With a Transformer you have Galvanic Isolation which can save your home and life. Each has pros and cons.MSEE, PEComment
this is a frame mounted pv array, not roof. grid power taken from sub-panel circa 1990 wiring (3 wires). given the configuration, it must be 2011.
the panel might support both. i checked the manual and saw the replacement of the gfci fuse in the panel. the advertising shows afci. it meets 2011 nec.
the consideration of transformer inverter is for the second array to be finished next year & the third array in 2019.Comment
i appreciate the honest remarks. most say the transformerless are better. but the grid operates using transformers...
the only thing i don't like about the transformer inverter design is the grounding of the pv modules (+dc or -dc) to ground.
it seems that some say the grounds (a/c and d/c) can be connected (in common), but this really bothers me. it seems 'bad practice' to have a hot dc potential sitting on ground shared by a/c circuitry.
before buying a transformer inverter, i would want to make certain the AHJ will approve separate grounding (a/c and d/c separate).Comment
That is not going to happen, so forget about it. It is required by code, and it would be extremely dangerous if you did not. additionally it can wreak havoc on your electrical system. To the point your TV and electronics would not work. So just get that idea out of your head as it is Best Practice.it seems that some say the grounds (a/c and d/c) can be connected (in common), but this really bothers me. it seems 'bad practice' to have a hot dc potential sitting on ground shared by a/c circuitry.before buying a transformer inverter, i would want to make certain the AHJ will approve separate grounding (a/c and d/c separate).
MSEE, PEComment
i live in florida and am told it is still under 2011 nec.
the first pv system build uses micro-inverters. i don't want to use them again. i just found 'a deal' on these 2011 nec transformer strings & am asking for input on using them. since they support both GFCI & AFCI, it seems like 'a deal'?
