Hello all,
I am located in northern Maine. I will be doing a grid tie system and ground mounting. I currently have 60 Hyundai 305W Poly HIS-M305 72 cell panels. I have not purchased anything else as of yet. The Sunny boy site has recommended two SB 6.0-1SP-US-40 - 240V and one SB 5.0-1SP-US-40 - 240V. Does this sound like a good inverter plan?
Any recommendations for a disconnect box?
I am also not grasping the wire gauge/type I need to use. My farthest panel will be about 200+- feet from the inverter.
I am planning a home made racking system. I need to dig down about 6 ft (through ledge) to get below the frost so I am in nightmare territory for this part of the project(ugh).
Anything else I need to be thinking about/purchasing?
Thanks!
Panel Specs:
DC Electrical Characteristics
STC Power Rating 305W
PTC Power Rating 273.3W 1
STC Power per unit of area 14.5W/ft2 (155.9W/m2)
Peak Efficiency 15.59%
Power Tolerances 0%/+3%
Number of Cells 72
Nominal Voltage not applicable
Imp 8.5A
Vmp 36V
Isc 8.8A
Voc 45.1V
NOCT 46°C
Temp. Coefficient of Isc 0.05%/K
Temp. Coefficient of Power -0.43%/K
Temp. Coefficient of Voltage -0.144V/K
Series Fuse Rating 15A
Maximum System Voltage 1000V
Mechanical Characteristics
Type Polycrystalline Silicon
Output Terminal Type Multicontact Connector Type 4
Output Cable Wire Gauge 12 AWG
Output Cable Wire Type PV Wire
Output Cable Wire Length 47.2in (1,200mm)
Frame Color Clear
Length 77.2in (1,960mm)
Width 39.3in (998mm)
Depth 2in (50mm)
Weight 51.1lb (23.2kg)
Installation Method Rack-Mounted
Warranty and Certifications
80% Power Output Warranty Period 20yrs
90% Power Output Warranty Period 10yrs
Workmanship Warranty Period 10yrs
UL 1703 Fire Classification Type 1
Compliances UL 1703, IEC 61215, IEC 61730
CSI Listed Yes
Thanks!
Panel Specs:
Number of Cells 72
Imp 8.5A
Vmp 36V
Isc 8.8A
Voc 45.1V
NOCT 46°C
Frame Color Clear
Depth 2in (50mm)
CSI Listed Yes
