Looking for some help. I'm on my 5th plumber (no joke), and nobody has seen anything like this. Moved into this house 2 months ago. It has a solar water heater paired with an electric water heater that is only a year old (solar heater is 10 years old I believe) . We are having a serious issue with sediment in our bathtubs and building up in shower heads. The water was also extremely hot so we turned down the electric heater down to 120 a few weeks ago... BIG problem. A week later we had yellow sludge water coming out of our hot water faucet. It looked like something out of ghostbusters. Now looking back the water looked a bit murky but I thought it was due to the hot water looking cloudy anyways. Here is what I have come up with so far. We are having expensive water lab tests for heavy metals and bacteria. Basic bacteria test indicate no harmful bacteria in water.
Copper pipes in house
Chlorine levels at water entering house (from hose near main) indicate adequate chlorine levels .3ppm
Chlorine levels are somewhat reduced when they reach our cold water faucet. But levels are ZERO in both solar and electric tanks.
I have had both tanks flushed AND drained.
Solar water heater tank water was yellow, with minimal sediment and I believed smelled bad.
Electric water heater tank water was yellow, sludge (separates to bottom).
A ton of sediment was in the electric heater.
The temperature of the solar heater is 160
I turned up the electric to 160 for a few days to kill bacteria, then back to 140 but noticed more yellow water today.
One of the plumbers plumber checked both anode rods, both corroded and nasty but thats normal right? We discussed replacing with zinc. Cost would be $400 to replace the just one in the solar heater. I thought this was high???
So... My next step is: water tests will be back in a few days
Do I ditch the electric tank and go solar only and replace anode rod with a zinc one? Potential down side is not enough hot water in the winter?
Or keep both tanks, replace both anode rods? And do a peroxide or bleach flush?
To complicate issues we are looking to get a water softener (I'm leaning toward potassium instead of salt).
I'm afraid of the potential issues of softened water in a solar tank thats maintained at 160. I believe we have to keep it high to keep the bacteria down because I still don't know what is happening to my chlorine in the tank?
I would like to filter out the chlorine anyways so I don't mind that it isn't there, but could it be causing bacterial growth??
Does anybody have any ideas why chlorine levels would diminish and be zero in both tanks when level was ok in cold?
P.S. Just talked to the previous owner- he said he usually kept the electric tank at 120 and thought maybe inspector turned up during inspections?? He said he didn't have any issue with sediment but I don't think he used those particular bathrooms much...
Pics would only upload sideways :-/ Bacteria water1.JPG Bacteria water2.JPG Sediment.JPG
