I have connected 75 modules to a delta rpi-m20a inverter using 4 strings. On checking the input and output voltages and current the values are appropriate. However when I check the MPPT1 and 2 values in the inverter there seems to be some discrepancy. What could be the cause of above? The input voltage stand at 743, 742, 743 and 710 volts and current at 5.1, 5.1, 4.9 and 4.9 Amperes respectively for the 4 strings. Also please note the input voltages on MPPT1 and MPPT2 are similar. However there seems to be a discrepancy in the current values which state 20.4A and 16.2A respectively.
MPPT input error in inverter
Never heard of that brand.
What is the Voc and Vmp of your panels ?
How many panels in series / parallel to each MPPT input ?
