Version:1.0 StartHTML:0000000167 EndHTML:0000007443 StartFragment:0000000457 EndFragment:0000007427 Hi – I have a Axpert MKS 5K inverter. Spec are as below.
MODEL: Axpert MKS 5K
Rated Power: 5000VA/4000W
INPUT Voltage: 230 VAC
Selectable Voltage Range: 170-280 VAC (For Personal Computers), 90-280 VAC (For Home Appliances)
Frequency Range: 50 Hz/60 Hz (Auto sensing)
OUTPUT
AC Voltage Regulation (Batt. Mode): 230VAC – 5 %
Surge Power: 6000VA
Efficiency (Peak): 90 %
Transfer Time: 10 ms (For Personal Computers), 20 ms (For Home Appliances)
Waveform: Pure sine wave
BATTERY & AC CHARGER
Battery Voltage: 48VDC
Floating Charge Voltage: 54 VDC
Overcharge Protection: 60VDC
Maximum Charge Current: 60A
SOLAR CHARGER
Maximum PV Array Power: 3000w
Maximum PV Array Open Circuit Voltage: 60 –115 VDC
Maximum Solar Charging Current: 60A
Maximum Efficiency: 98%
Standby Power Consumption: 2 W
Can I use Sharp NA-E135l5-B panels on this inverter. Looks like the MPPT has a wide range voltage.
Spec = Maximum power Pmax 102.4 Wp / Open-circuit voltage Voc 56.8 V / Short-circuit current sc 2.76 A /
Voltage at point of maximum power V mpp 44.0 V / Current at point of maximum power I mpp 2.33 A /
Nominal operating cell temperature NOCT 46 °C
OUTPUT
Surge Power: 6000VA
SOLAR CHARGER
