Does it effect the amps & volts just wondering.
Wires in direct sunlight
not really. copper resistance increases about 0.4% / deg C, so to the extent that wires in direct sunlight get hotter, you might see a small difference. However, that might be offset by better cooling airflow than the wire would get in conduit.CS6P-260P/SE3000 - http://tiny.cc/ed5ozx -
Direct sunlight will break down the insulation of the wire as well as heat up from the sun. That will certainly reduce the amps it can handle which is why you size the wire for the load, distance, and environment.
The wire to use for most solar pv system has an insulation rating with a "-2" on the end which normally indicates it is ok for PV.Comment
The -2 wire is not usually rated for direct sunlight exposure. PV Wire is appropriate for solar installations with wire runs not in conduit.Direct sunlight will break down the insulation of the wire as well as heat up from the sun. That will certainly reduce the amps it can handle which is why you size the wire for the load, distance, and environment.
The wire to use for most solar pv system has an insulation rating with a "-2" on the end which normally indicates it is ok for PV.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
Ok thanks, my system flat lines as to same power, in the heat of the day in Florida same output 10 to 2. Must be the panels getting hot.Comment
