Hi Everyone,
My name is Mike and I'm in the process of putting twelve 230W REC panels on my roof in San Francisco. They would be in a 4x3 array. I have a flat roof with a reflective-coated membrane, so we decided to go with a ballast rack system. This lets us re-coat the roof when we need to and doesn't require any penetrations.
I'm at the point where I have all the panels, I have the microinverters and my layout, and I'm ready to build a rack system out of 2" galvanized angle iron. I've put together the rack for one panel just to work out the supports and bracing and it looks pretty good. Before I go any further, I have to pull the permit with the city and show my design to the city structural engineer since it's not a pre-manufactured system.
Can anyone help me with how to figure out what ballast weight is required for my system?
And does anyone have recommendations on what to put under the racking material to protect my roof? I was planning on putting down 6" wide strips of rubber roofing membrane, then 1" thick redwood, then screwing the 2" angle iron down to the redwood with 3/4" screws. The roofing membrane has adhesive on both sides, so that provides some connection to the roof. But I definitely want to put cement blocks in the racking trays too, I just don't know how many I need to put in there. Obviously, the least I could use to be safe would be preferable.
So if anyone could give me a few pointers, I'd really appreciate it!
Cheers,
Mike
Cheers,
Mike
