Are there any test results that didn't come from SolarEdge that show the SolarEdge as more efficient?
enphase s280 with LG315N1C-G4
NREL has tested as well.
There are not even any tests from enphase showing them more efficient than solarEdge.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Enphase Solar Panel Microinverters are the industry's first grid-forming inverters eliminate battery sizing restriction. Get a quote now to get upto 25yr warranty.
SolarEdge ranges from 97.5% to 98.3%
And the optimizers are 99.5%.
http://www.solaredge.com/files/pdfs/...tasheet-na.pdf
So even at lowest of 97.5% and 99.5% combine to 97.0125%. ( marginally greater than 97%) to 98.3% and 99.5% combine to 97.8%OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
If you do not have any shading issues The SMA is what I would want. You can get all of the data you need from the Sunny Portal. For me, it is not only the clipping to consider, which type will harvest more on cloudy or partially cloudy days should also be considered, IMO. I like the production that I see from high voltage strings vs micros on any given day though.Comment
Shading can also mean bird poop on a panel, or snow. I am new to this, but I can't see going SMA if EnPhase is the same price.Comment
Bird poop would have to cover most of the module to make an effect like shading. One or two spots does not make a difference with either system. Snow will affect both systems equally also. I am curious why would you think the micros are more productive over a string inverter design in full sunlight? Also, have you considered the LG modules with built in micros?Last edited by ncs55; 05-08-2016, 09:38 PM.Comment
Then there is some efficiency gains with inverters like solarEdge, at near constant DC side voltages.Last edited by ButchDeal; 05-08-2016, 09:45 PM.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
What do you mean it does not exist? http://www.lg.com/us/commercial/MonoXACe/index.jsp A well producing system is more than the wattage of the modules used in that system. Consider how the A and V work with the inverter as well. The difference in using 300 or 320 Watt modules is usually only a few modules more or less in the system.Comment
You never know do ya. I have been waiting for a customer to request these so I can monitor them. My supplier has them in stock and they look pretty robust. The inverter is NEMA 6. Internal temp is rated for 194 F. Mostly here in S.D. the modules run at around 150-160 F in full sunlight. The output specs look pretty good.
I don't know why a customer would request them. Why would anyone want 300 watt panels when LG makes 315 and 320 watt panels, unless the 300s were lower dollars per watt, which a customer would not have visibility on. So the installer would have to be the one to talk the customer into it by offering a lower overall price due to reduced labor or something. It just seems like a short-lived product that someone may have trouble replacing in the future if they needed another one and could not find it.Comment
If a customer gets a lower price quote from it, then sure. But I can't picture that happening - as LG, the distributor, or the installer would find a way to keep that from happening.Comment
