enphase s280 with LG315N1C-G4
One thing hard to quantify that may add to the perception and reality of clipping is the amount of overdesign (or looked at another way, the conservative guarantees or panel rating claims by mfgs.)
If, for example, a panel claims 315 Watts, +5/-0% at S.T.C., it's output might be and probably will be greater than 315 Watts at some time, not only because of some combination of higher irradiance, low incidence angle, low ambient temp. and a breeze, but also because it's efficiency is perhaps and probably a couple % or so higher than the spec sheet says.
Still, the amount of time an LG 315's output will be > 280 Watts and how much in excess of 280 Watts it will actually be will probably result in a small amount of the total annual output being lost due to clipping.Comment
Enphase has to be developing a larger inverter to come out "soon", right? Jrfiero is clipping with 315W panels. My LG 320W panels are sitting at my home, ready for install. What's LG going to have next year? I assume Enphase must have a new inverter in the hopper or they won't be perceived as an innovator.Comment
The S280 is the new inverter from enphase. They are late coming out with it and now it is pretty much too little too lateEnphase has to be developing a larger inverter to come out "soon", right? Jrfiero is clipping with 315W panels. My LG 320W panels are sitting at my home, ready for install. What's LG going to have next year? I assume Enphase must have a new inverter in the hopper or they won't be perceived as an innovator.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
that is my point. enphase is behind the curve on current production levels and is more costly than the competition.
Why pay for premium modules like LG310s and then not harvest all the power?
It would cost LESS on most systems to install SolarEdge than to install enphase (very small systems are the exception).
SolarEdge doesn't have the clipping and is easily able to keep up with new production levels.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
As has been suggested, running PVWatts and using the advanced parameters to adjust the DC to AC size ratio to = panel size/inverter size may give an approximation of clipping penalty by comparing the annual output to that using a "larger" inverter that doesn't clip and comparing the two #'s. Might be useful.
SolarEdge doesn't have the clipping and is easily able to keep up with new production levels.Comment
I just had that exact system installed. 7kW total, 22 LG315N1C-G4 LG panels (315W) and S280 inverters. Enphase says "Commonly used module pairing – input power: 235 W – 365W", really it depends on the max input voltage with is 48V.Comment
Engineer, what a wonderful system! I installed 12 lg 310 with the M250 so I'll be studying your system to see how much power I'm losing by not having the s280's instead.Comment
I installed myself, and received the M250's at a great deal. The cost wasn't a huge concern, but I couldn't justify the 60 dollars extra for each inverter. I'm guessing I average 30 watts of clipping for 3 hours a day which totally stinks. But at the end of the day I'm enjoying the project and even thinking about my next addition. Power bill looks like it will be zero cost which is awesome.Comment
That's great, good for you. Wish I could have self installed, but I don't know enough about solar to have done that with my installation which was a little complicated. Even my installer which has been doing in the business for 30 years (long before it because a common thing) got down checks on the first inspection. Mainly around grounding, they needed to do the panels grounding slightly differently, separate the sub panel ground from the sub panel neutral, and run a separate #8 ground wire from the sub to the main (instead of the 10 gauge which was in the four wire 6 gauge Romex). All this for lightning protection it seemed.I installed myself, and received the M250's at a great deal. The cost wasn't a huge concern, but I couldn't justify the 60 dollars extra for each inverter. I'm guessing I average 30 watts of clipping for 3 hours a day which totally stinks. But at the end of the day I'm enjoying the project and even thinking about my next addition. Power bill looks like it will be zero cost which is awesome.Comment
If that 30 Watts clipping X 3 hrs./day is all that's lost from the entire array production, I' d guess it will take some time for the NPV of the lost production from that clipping to equal $60/panel.I installed myself, and received the M250's at a great deal. The cost wasn't a huge concern, but I couldn't justify the 60 dollars extra for each inverter. I'm guessing I average 30 watts of clipping for 3 hours a day which totally stinks. But at the end of the day I'm enjoying the project and even thinking about my next addition. Power bill looks like it will be zero cost which is awesome.Comment
