APSystems ECU-3 scraping
  • Filter
  • APSystems ECU-3 scraping
    While APS EMA site does provide some functionality to view energy production, it is very limited on creating reports and show energy production per panel/micro-inverter and break it down per day/week/month. Their reports hide individual panels and do not allow me to view if some panels are degrading at much faster pace than others.
    Has anyone tried and succeeded in getting the ECU-3 data scraped to local database for storage? Possibly there is an undocumented API that allows reaching the local DB, otherwise I will be looking into possibility of 'scraping' data from html page and loading into local database.
    Thanks!
  • #2
    I think this is a function beyond most homeowner systems and is more suited to large grid installs ?? It's above my pay scale
    • #3
      I do agree this is not something that every homeowner is after. However there are quite a few APS ECU-3 installations out there and I was hoping someone had already been able to find a backdoor to the webserver for additional analysis.
      • #4
        2by4, i want to be able to do the same exact thing with my APS inverter. Hopefully someone knows a trick.
        • #5
          I think there should be a local database query to load and excel sheet directly from the ECiU. The problem is finding it..
          • #6
            Resurrecting an old thread because I've been thinking about the same problem. Did anyone find or build a solution for this?
            • #7
              I do not think this is just for large systems. If you have a panel that is not producing as much as it should everyone should want to know about it. If a tree shadows a panel or it just needs cleaning it would show up in the report. If an inverter has a problem we all should know about it. I would like to be able to see how each panel did when compared to the array average for the last x data point sets where x could be any number but week month or year come to mind.
              Need to filter out night hours as an option.
              I like the older layout better than the new one. I would like to be able to switch back to the old one some times.
              Is anyone scrapping data?
              • #8
                Agree that it's not just for large systems, and if done right, could also be used to push up to PVOutput, for example.
                I have an older ECU (circa 2013) and the HTML would be easy to scrape and parse. Are there "best practice" polling intervals? Will perhaps have a go sometime soon, but also interested to know if anyone else has already done it.
                • #9
                  Wrote a quick python script to scrape from my ECU. Requires python 3.x (scripting language) and the "BeautifulSoup" module. Might not work for newer models, but you'll get the idea. The forum won't let me attach it as a file, so you'll need to grab the gist from https://gist.github.com/anonymous/c4...bf83c69fd6a1ee
                  • #10
                    Does your script load the entire DB to a spread sheet?
                    • #11
                      Don't have access to the DB, just the web pages which show current power output and summary data. Right now, the scriptjust prints the current power output data.
                      • #12
                        If we could get access to the /cgi-bin/ directory there is a chance we could figure out how to query the database.
                        What happens if aps website goes down or away?
                        • #13
                          Hi, I scrape the current readings from the APS ECU and send the data to PVoutput.org so it is easier to see and compare (read Compete) with my neighbour.
                          Are you still interested?
                          I am using an Arduino/ESP8266 to do the hard work. I have made a few for other people. Google APSECU2PVO .
                          My data andmy neighbour
                          https://pvoutput.org/comparelive.jsp...868&sid1=29357
                          Terry
                          • #14
                            Any update on this? the python script doesnt work with my ECU3 v.4 on software v4.1NA I would love to run this on my debian box to push to pvoutput from the ECU or something..
