Improved Snow Removal Tool
You could tie that aluminum pole to the frame ground for protection. Otherwise if you slip and the pole pokes a hole
in a panel, it could pick up 400VDC here. Bruce RoeComment
As soon as Phoenix has a problem with snow accumulating on solar panels I'll begin working on the prototype. It was low 70's last week while I was out pouring concrete in a T-shirt so it might be awhile.
Right now, my compressed air idea is used to help clean pools.
Dave W. Gilbert AZ
6.63kW grid-tie ownerComment
I'm having trouble visualizing it; you have a sketch? Seems like nozzles & valves would be needed
for each panel. My panels are hundreds of feet from any building, but I did drop a 20A AC line in
the trench for some outlets. Bruce RoeComment
I'm just thinking of a more typical home install where you could manually open valves to blast air under the snow accumulation on the top panels and hopefully trigger an avalanche. I'm sure there are snow conditions where it would not always work as planned. Your arrays are quite extensive and remote so not as easy for you I'm sure. It's been 26 years since I lived in the snow and back then I had an air-to-air solar setup for heat. I could clear the panels by manually turning on the circulation fan.Dave W. Gilbert AZ
