I have solar panels with a SolarEdge inverter. The display froze on me before and just shows a steady backlit blue display with no information on the screen. Just a blank blue screen and all three lights are lit steady (green, yellow and red). But the inverter seems to be sending updates to the monitoring app since I periodically see current updates.
From other posts on this forum, this seems to be a known issue. I have some questions.
- What causes this?
- How do I recover from it? One post said to turn off and back on the entire system.
- Can I turn it off and on at night? Will it turn on properly at night since it can't do its startup routine by pairing with each optimizer.
- Should I reset it by turning the on/off dial at the bottom part of the inverter, the on/off switch next to the display button under the top part of the inverter, or by using the emergency switch to shut down the entire system?
- Should I leave it alone and reset it in the morning? If I do, will the display burn out by being lit steady all night long?
Can someone explain what each of these different switches do and when I'd need to use each one of them? Is there documentation that explains all this? I can't find anything on SolarEdge's site.
- What causes this?
