I have 3 of the 100w semi flexible Renogy solar panels, and while I was hooking them up to test them out, a gust of wind came and knocked them off platform i was setting them up on onto the ground about 4 feet below. It wasn't a big drop and the wire caught on the platform and lessened the blow a bit, but upon testing the output, two of the panels are putting out about 5A and one is putting out 2.5A.
When I connect the panel directly to a car battery in full sun (in Tennessee) its still putting out 2.5A. If I short out the two wires momentarily the amperage jumps to 5.3 amps. The volatage i measure on the panel is 19v. The battery's voltage is 13.2v. The short circuit voltage on the panel is reported as 6.2A and the open circuit voltage says its 21.7V so 5.3A and 19V seems like itd be about right for the Tennessee sun hitting the panel.
My question is why is the panel only putting out half the amperage as the other two into the battery, despite it being able to produce the full amperage when shorted?
