I have had my SolarEdge system for less than a month and have had 3 occasions now where the system appears to freeze up. The LED display that shows you current power numbers, among a thousand other little bits of information as you cycle through screen to screen, will at random times.. so far, about once a week.. it will randomly just turn on the backlight to a blank screen.. and stay stuck there.. the Production light goes off and for all intents and purposes sits dead in the water..
The only way to get it back is to shut down the entire system.. all the way to the Utilities breaker.. then the system will 'wake up' again, repair with each optimizer and start humming along again..
During this time I get no updates to the Gateway, but the inverter fans continue to run...
Anybody experience anything like this?
Installer says it all looks 'fine'.. which it does, after I reboot the system... I finally took some video of the system while it was in this state.. no response from installers or solaredge about that yet...
It happens when I'm away, of course.. and as far as I know I don't get any power generated while it is like that...
