Looking for help in choosing Panel MFG for 5KW grid tie system in New Mexico-will be using Enphase inverters and mounting on Flat Roof--also need suggestions on mounting sys with no roof penetrations --will have about 20 panels- price, quality, efficency, size ? Thanks Bob
How To Choose Best Panel for Grid-Tie Sys?
That's called a ground mount, or top of pole mount. Panels on a roof, MUST be achored to the structure to keep them from being blown off. For some standing seam metal roofs, there are some clamp-on brakets for the array racks, but I don't think that's applicable to you.need suggestions on mounting sys with no roof penetrationsPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Hi Mike---In our area of New Mexico --many people choose to use a ballisted system by unirac--I think it's call rapidrac--but almost 200 dollars per panel--looking for other less expensive ideas--these racks lay on roof at 10 degree tilt and have bricks to add weight--I don't want to put holes in the roof structure and am happy with a low tilt-----What panel manufacturers do you like?Comment
I like Evergreen, because they are USA made, and have better off-axis production, but others don't like them because they are about to go bankrupt. Nearly all name brand panels are pretty good.What panel manufacturers do you like?Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I don't think evergreen is compatible with enphase either. I like the evergreen panels, but this rules them out for me.Comment
