Announcement
No announcement yet.
charge controller with a grid-tie inverter
  • Filter
  • charge controller with a grid-tie inverter
    Hello, I am 19 year old college student. During this summer, I have been researching solar energy, but I have a lot to learn still. I just built a 36 cell solar panel, using 3x6 .5 volt, 3.6 amp cells. I am planning on building additional panels. I am looking into using a grid-tie inverters. Would I need to wire my solar panel up to a charge controller before wiring into a grid-tie inverter? And could I wire multiple solar panels together in series and then into one grid-tie inverter? And, what is the difference between a standard grid-tie inverter and a "power jack" grid-tie inverter?
    Thank you for any advice!
  • #2
    Cool, that can be a lot of fun
    Generally, you need to have a permitted installation (Building structure and electrical permits) and then the electric company will consider allowing you to feed into their grid
    Non-UL listed panels (anything homemade) would not be permitted. Part of the UL process is verifying the panels can withstand 600 - 1,000 Volts in case of a fault somewhere.
    One is legal and permitted, the power-jack is not.
    Pure Grid Tie uses a high voltage string of panels to feed 500VDC into the inverter for conversion to AC for the grid.
    un-permitted and non-UL certified gadgets attached to your house generally will void your fire insurance. Even table lamps you buy at the store are UL listed.
    Homemade panels are good for running a pump in a fishpond, or lights in a garden shed.
    • #3
      Thank you very much for your input. I was not aware that home made solar panels and power jack inverters were illegal for plugging into the grid.
      • #4
        Bummer isn't it.
