So, my guys stumped me with a question and i want to talk through the issue here, although writing this has made me understand most of it by talking it out.
a) SE has 5250W max per string, but you can combine strings in parallel, which is just fine.
a.1) this means that I design them as 2 strings of 15, going into one string input, and another combo of 2 strings of 15 into the second input.
a.2) I'd thought this went into electrically separate inputs in the inverter)
b) yesterday an installer asks me another question, and shows me a pic of the SE inputs, and I see that both of those inputs are actually on the same terminal block and are combined in parallel directly at the input!
As I write this, it becomes obvious to me, but please - confirm this for me still - it's simply that everything is getting equalized at the panel level and, quite specifically, there are no inverter-interior gains/modulations made to the circuit, because everything is modulated at the optimizer. This is all a no-brainer now that I'm writing it out.
So, it sounds like there is nothing wrong with combining everything on the roof, and running only one set of wires down to the inverter. Maybe a spec on that input block regarding maximum wire size, which I'll look into directly after this, but nothing else. I think we've just been wasting wire for a while now.
Is there anything I am missing here?
