Mirroring/intercepting SunPower Monitoring Traffic?
Yeah, unfortunately, around June 25th of last year (2017), Sunpower rolled out new firmware that uses a different site, and encrypted data traffic for their data uploads. That apparently applied to all micro-inverter-based installs, so our main house got hit by that, and I have no way to retrieve per-panel data now. On May 11th of this year (2018), this firmware update also hit our rental house (which uses DC from the panels to a single inverter), as well. Now the supervisor still pings the sunpower server using the old protocol, but that's just the 100/102 message (which appears to just be an "I'm alive and OK" message). All other traffic goes to a different server, and is encrypted. Very, very unfortunate. SunPower just does not realize that, as system owners, this is _our_ data, not theirs... -
I am trying to see why these seemingly great solutions are not working for me. Can someone send me a tcpdump statement they used to find the post data? Here is what i have tried and the only thing returned is below.
I am fairly certain the IP of my SunPower supervisor is 192.168.1.3; the not dst statements are to eliminate a VERY chatty DNS lookup
tcpdump -vvv "src 192.168.1.3 and not dst google-public-dns-b.google.com and not dst resolver2.opendns.com and not dst google-public-dns-a.google.com"
tcpdump -s 0 -A 'src 192.168.1.3 and tcp dst port 80 and (tcp[((tcp[12:1] & 0xf0) >> 2):4] = 0x504f5354)'
I am only seeing the 100/102 messages - i have been monitoring for an hour during daylight - overcast, but still generating some power.
100 SPMS 10 ZT163185000441C1526 20180525004318
102 AiF/Gs2xWTn4EpZdZF17Leave a comment:
it is interesting to me that my system keeps chugging along with the script i wrote so long ago. i am not sure why other people are getting firmware updates but i am not; i have not installed any kind of firewall rules for the supervisor so i feel like it should be able to download whatever it wanted to. maybe it is a misconfiguration by the installer? at any rate i'm OK with it!Leave a comment:
boing,I had drawn conclusions similar to intipower's findings. (I wish I had seen this thread first before having to discover it on my own!) A couple of additional/similar findings are below. I'm wondering if my supervisor is a bit different than yours based on what I'll highlight below.
First, this is what mine looks like. Note the two LAN ports on the top right. Is that how all of yours are too?
Am I overlooking anything, or does that seem to be the best approach?
All the SunPower Supervisor RS-485 info is in the first 5 or so pages, then everything changes to pvs5. Look for robillard astroboy and of course sensij. It is a moving target and SP keeps making changes.
This still worked for me as of 5/18 on the April firmware.
However, now that I'm on the May firmware "Version 2018.5, Build 2039" aka "v2018.05.32", I keep seeing this error:
Code:{ ... "controller": "ConfigListController", "url": "/devices", "call": "/cgi-bin/dl_cgi?Command=GridProfileGet", "data": { "result": "error", "msg": "Could not connect to mime.", "success": false }, "method": "GET" }Leave a comment:
To confirm things on my end I reconnected my supervisor to WiFi and now see traffic to several IP addresses. Most appear to be DNS resolvers, but 50.112.130.148 and 52.7.213.242 are Amazon Web Services. One of note is this from tshark: 192.168.1.3 → 50.112.130.148 TLSv1.2 432 Application Data. This would imply that the traffic is indeed now encrypted. Also, on reconnecting to WiFi, my supervisor updated to Firmware 2018.4 Build 1092 which appears to be the latest.Leave a comment:
I also have a SunPower solar system - 12 panels that produce great energy in Southern California. I was trying to implement @@JJNorcal's solution to essentially intercept the traffic from the PV. I believe i identified it on the network because it's using the HF-LPB100 wireless NIC. Thanks to great instructions on setting up the Raspberry as a bridge, I got everything up and running fairly easily. I believe I have configured the settings on the application correctly but i am not seeing anything recorded. locally or at PVOutput.
ehampshire, I am reasonably adept at Python so might give your approach a try. Thanks for documenting all of this. Have you been able to capture data via your methods?Leave a comment:
I am presently looking into getting a SunPower Equinox system.Ack! For some reason I didn't get an email alert there were updates to this thread. I have lost my monitoring via the tcpdump/snooping method as well. My direct queries to http://sunpowerconsole.net/cgi-bin/d...and=DeviceList also changed the data format, so I'm pretty sure our PV supervisors got a firmware update. I've updated my direct query scripts to parse the new data properly, I will give an explanation below. I thought I'd share my PV's version:
"supervisor":
"SWVER":"5.0.0, Build 325",
"SERIAL":"ZT162585000441C1402",
"MODEL":"PVS5"
So, I'm not sure if they turned on TLS/SSL or why we lost all our data. I think it may have switched over to using the cellular connection - I can confirm my PV supervisor has a SIM card and is able to communicate over the cell network. I no longer see 140 or 130 messages coming across in the clear. But, at least direct query still works so I can get my production values (I still haven't worked out consumption on this). Here's the new format:
PV monitor (140 line):
"ISDETAIL":"1",
"SERIAL":"PVS5M508095c",
"TYPE":"PVS5-METER-C",
"STATE":"working",
"STATEDESCR":"Working",
"MODEL":"PVS5M0400c",
"DESCR":"Power Meter PVS5M508095c",
"DEVICE_TYPE":"Power Meter",
"SWVER":"4",
"PORT":"",
"DATATIME":"2017,06,30,14,56,51",
"ct_scl_fctr":"125",
"net_ltea_3phsum_kwh":"-640.39",
"p_3phsum_kw":"-1.8784",
"q_3phsum_kvar":"0.5875",
"s_3phsum_kva":"2.0794",
"tot_pf_rto":"-0.9033",
"freq_hz":"60.02",
"CAL0":"125",
"CURTIME":"2017,06,30,14,57,04"
Inverter example (130 line):
"ISDETAIL":"1",
"SERIAL":"414051637006465",
"TYPE":"SOLARBRIDGE",
"STATE":"working",
"MODEL":"AC_Module_Type_C",
"DESCR":"Inverter 414051637006465",
"DEVICE_TYPE":"Inverter",
"SWVER":"951007408",
"PORT":"",
"MOD_SN":"",
"NMPLT_SKU":"",
"DATATIME":"2017,06,30,14,56,21",
"ltea_3phsum_kwh":"284.4779",
"p_3phsum_kw":"0.107",
"vln_3phavg_v":"247.3326",
"i_3phsum_a":"0.4554",
"p_mpptsum_kw":"0.112",
"v_mppt1_v":"56.2324",
"i_mppt1_a":"2.0239",
"t_htsnk_degc":"30.75",
"freq_hz":"60.042",
So, because I'm lazy here's the copy/paste from my code showing what I used to be parsing (commented out with the # sign) to what the values now are:
#insert_line.append(x["ac_curr"])
insert_line.append(x["i_3phsum_a"])
#insert_line.append(x["ac_power"])
insert_line.append(x["p_3phsum_kw"])
#insert_line.append(x["ac_volt"])
insert_line.append(x["vln_3phavg_v"])
#insert_line.append(x["dc_curr"])
insert_line.append(x["i_mppt1_a"])
#insert_line.append(x["dc_power"])
insert_line.append(x["p_mpptsum_kw"])
#insert_line.append(x["dc_volt"])
insert_line.append(x["v_mppt1_v"])
#insert_line.append(x["energy_total"])
insert_line.append(x["ltea_3phsum_kwh"])
#insert_line.append(x["heatsink_temp"])
insert_line.append(x["t_htsnk_degc"])
I've uploaded what I have for parsing to the capture folder of my project here: https://github.com/ehampshire/sunpower/tree/dev/capture . It's called sp_monitor_json2.py and has a conf file (sp_monitor_json.conf). The way I reach my PV monitor is through a Raspberry Pi in my garage hooked into the installer port on my PV supervisor. This Pi then bridges to my wireless network and I put in a static route on whatever machine I want to reach it through, like so:
echo "Adding static route to 172.27.153.0 netmask 255.255.255.0 via 192.168.1.163"
route add -net 172.27.153.0 netmask 255.255.255.0 gw 192.168.1.163
Can anyone confirm if the above workaround still works? I did see some posts mentioning they changed something that made getting detailed stats impossible.
Thanks!Leave a comment:
Guest repliedMy PVS doesn't seem to update automatically. The install company set the CT scaling to the wrong value and when I connected to fix it on 23-Jan the system updated to 327.Leave a comment:
Guest repliedLeave a comment:
Anyone know when the software on the PV supervisor was updated again. I had not noticed it went from build 325 to "SWVER": "5.0.0, Build 327",Leave a comment:
i had missed the updates to the thread as well. interestingly i have had no drama like any of the posters here had recently. i don't know if my supervisor is capable of remote firmware updates or not, or if somehow i'm just further down the list, but i have had 130 messages in the clear continuously all this time. my script continues to snarf the data.
i guess i would not be surprised for SP to try to turn on encryption as it's essentially best practice, especially if they are sending consumption data - which can easily tip off whether or not someone is home to a careful observer.
one question would be if the firmware updates come from a different IP address (than the monitor), perhaps some of us could block that IP. another is if this method of logging into the supervisor on the other ethernet interface still works even when the snooping method does not (seems likely, but i never investigated it.)
finally all of this stupidity could be avoided if SM would just provide an API so that other programs could just ask for the data...
Hi ehampshire. I stopped getting my notifications about thread updates too.
So it looks like the software version of the PV Supervisor went from 5.0.0 build 313 to 5.0.0 build 325.
It looks like the update changed the inverter field names and they added two fields ( MOD_SN which is maybe the module serial number and NMPLT_SKU which I will guess means "name plate stock keeping unit" but these are probably populated in newer modules.) For my data they don't have anything in them.
I'm just dumping the data into a mongo database so it worked out that no data lost since mongo doesn't define a schema to worry about (lucked out on that one.) I'll just have to remap the names for any data presentation layer in my applications.
You should switch from SQL type database to mongo since the data is reported in json and mongo stores data as json documents it's a much nicer solution with way less overhead on the DB setup and you won't loose data if they update things and switch field names, etc.
"supervisor":
"MODEL":"PVS5"
"ISDETAIL":"1",
"STATE":"working",
"SWVER":"4",
"PORT":"",
"freq_hz":"60.02",
"CAL0":"125",
"ISDETAIL":"1",
"STATE":"working",
"PORT":"",
"MOD_SN":"",
"NMPLT_SKU":"",
"freq_hz":"60.042",
route add -net 172.27.153.0 netmask 255.255.255.0 gw 192.168.1.163Leave a comment:
