MorningStar Tristar or Midnight Charge Controller For Small Off Grid System?
When I viewed their website, and the specs for the 45Amp model, it appeared that it did have "data" logging capablity which I assumed meant it allows you to use an ethernet cord to see the information.
But anyway, my main question here is, what makes Morningstar's controller better than Midnight's charge controller that is around the same specs? I definitely want to expand my system in the future, but both controller manufacturers seem to allow that, so I'm a bit lost as to which one to go with.
Whoa. here's my data.
Morningstar Only the MS 60A mppt has the ethernet port. The MS 45A I think, has a serial port (my 60a does) and I connect it to my laptop with a SERIAL-USB adapter. The morningstar MSView program downloads the log files, and also can re-program the settings. MSView is a very powerful program, but the .CSV file it outputs, needs to be massaged in a spreadsheet.
The ethernet is just a Viewing HTML page, not interactive.
Midnight Classic. I've never tried to get the logs out of it, I just need the daily stats that I can read off it's monitor panel (over ethernet) The Classic has a nice ethernet remote control app, I use the float/absorb controls, and the ability to tweak the voltages remotely, enables me to get the two controllers to sync nicely.
With my 2 Evergreen arrays, the Morningstar seems to have a better efficiency and robustness than the Classic. it's also much cooler and quieter (no fans)Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
