Imeon 3.6 Smart Inverter ?????
  • Wazza
    • Feb 2015
    • 6
    Hi Guys
    I am looking at this smart inverter i would like to get some honest opinion on it has anyone heard of them before etc
    what size battery bank can i hook up to this thing and what would the best aH rating be , i know it would be a 48VDC bank and probably 6v cells i guess
    also the panels i was looking at are ReneSola : Virtus II 300W : Solar Panels, 10 of these should give me close to the 3000w the inverter can handle correct??
    in South Africa we expect around 5.6 hours of good sun per day
    I am planning on running this mostly in off grid mode with the option of also using the grid if needed
    any advise or help will be very much appreciated IE dont be shy to tell me im talking hogwash
    Cheers
    Warren
    specs are here http://www.solarsolved.co.za/datashe...idinverter.pdf
    GRID AC (ON-GRID & OFF-GRID) IMEON 3.6
    Nominal output power 3000 W
    Maximum output power 6000 W(2) with grid tie
    AC voltage (input & output) 230 Vac (±15 %) / 50 Hz (±5 %)
    Nominal output current 13 A
    Maximum output current 26 A(2) with grid tie
    Feed in to grid Programmable (yes by default)
    Energy consumption Programmable priorities (PV / Storage / Grid)
    SOLAR INSTALLATION
    Maximum input power 3 150 W
    Start-up voltage 150 V
    Number of MPPT inputs 1
    MPPT voltage range 120V – 450V
    Maximum input current 18 A
    Maximum input voltage 510 V
    Maximum efficiency DC to AC : >95,5% (94,5% EU)
    Solar production use Programmable priorities (PV / Storage / Grid)
    BATTERY & CHARGE
    DC voltage 48 Vdc
    Maximum discharge current 80 A
    Maximum load current 25 A
    Type of batteries Gel, AGM
    Charging curve 3-phase (Bulk / Absorption / Float)
    Maximum efficiency PV to battery : >94% / Battery to AC : >93%
    Battery charge Programmable (threshold / timing range via AC Grid)
    Battery discharge Programmable ( 2 thresholds according to grid availability)
    GENERAL
    Dimensions (w x h x d in mm) 540 x 440 x 135
    Protection category IP 20
    Weight 18 kg
    Connectivities TL (transformless)
    Connectors USB / Modbus / Ethernet - IP (option)
    Conditions of use Humidity level: 5 to 90% without condensation T°C : 0 à + 50°C, degressive power >40°C (15w/°C)
    Standards EN 62109-2 / EN 62109-1 / EN 62040-1 DIN V VDE V 0126-1-1 (+VFR2013) / VDE-AR-N 4105 / DIN VDE V 0124-100
    Guarantee 5 years / Extensions to 10 years (optional)
    Photovoltaic panels
    IMEON ENERGY
    300 Rue Pierre Rivoalon
    29200 Brest - FRANCE
    +33(0)1.84.17.51.15
    contact@imeon-energy.com
    Energy Self Use
    Flyer V3B April 2014 Cancels & replaces precedent versions
    (2)
  • Wazza
    • Feb 2015
    • 6
    Nobody have any info on this Inverter ???
    or is my post in the wrong section maybe ????
      Your post location is good enough - seems it is an off the wall brand
      • Wazza
        • Feb 2015
        • 6
        Hi Rus
        thanks for the reply
        what does off the wall mean ?? sorry for the dumb question
        regards
        Warren
          Originally posted by Wazza
          Hi Rus
          regards
          Warren
          A no name product - unknown product
            Just post in one thread please. The second has been removed.
            • Eghardt
              Hi Guys
              Cheers
              Warren
              SOLAR INSTALLATION
              BATTERY & CHARGE
              DC voltage 48 Vdc
              GENERAL
              Weight 18 kg
              Photovoltaic panels
              IMEON ENERGY
              +33(0)1.84.17.51.15
              Energy Self Use
              (2)
              Hi Warren,
              We are a solar company in Port Elizabeth and install many standalone and grid-tied systems using various inverters like SMA, Microcare etc. We have installed 5 Imeon`s this year with great results.
              I would highly recommend the Imeon as a great hybrid inverter. I can give you a list of our happy customers if you wish.
