Hi all, I am about to install solar for my shop at my house. Here are the specs on what I'm installing:
6 each Topoit 245 watt Mono panels
Watts (STC) 245W
Watts (PTC), No
Maximum Power (Vmp) 49.51V
Maximum Current (Imp) 4.95A
Open Circuit Voltage (Voc) 59.45V
Short Circuit Current (Isc) 5.54A
Power Tolerance ±5%
Module Efficientcy No
My equipment is:
Outback GVFX3648 Inverter/Charger, 3600W, 48VDC, 120VAC, 45A charger
Outback FLEXmax FM80 Charger Controller
Outback MATE3 Control Module and Display
Outback HUB-10 Communications Manager
Outback RTS Remote Temperature Sensor
Prewired AC and DC boxes with 120VAC Bypass and Type B Outlet
FLEXnet DC
surge protector for 120V 60Hz applications
80 amp charge controller breaker
175ADC breaker
GFDI
1 x PSX-240 Auto transformer
Now my question is, how can I tie them all together in parallel? How many string before I need a combiner box? Can I use branch connectors and bring one run down to a fused DC disconnect? My intentions are to add more panels at a later date and time. Thanks in advance for any help.
Watts (STC) 245W
Watts (PTC), No
Power Tolerance ±5%
My equipment is:
FLEXnet DC
175ADC breaker
GFDI
