Purchased Renogy 4 X 100W Monocrystalline panels and MPPT Controller which I will place onto of my RV rough, it came with 10 awg MP4 solar cable, do not know if I will go with a larger wire size, 8 or 6 maybe.
I inadvertently got a fancy combiner box off ebay which is fused. it holds 4 10x38 fuses as pictured
http://www.ebay.com/itm/131232900049...%3AMEBIDX%3AIT
I plan to wire up the panels in parallel, if I understand it, so if one panel gets shaded it does not affect the entire system.
The panel specifications are:
Maximum Powe rat STC (Pmax) 100 W
Optimum Operating Voltage (Vmp) 18.9 V
Optimum Operating Current (Imp) 5.29A
Open-Circuit Voltage (Voc) 22.5 V
Short-Circuit Current (Isc) 5.75 A
Maximum System Voltage 600VDC
Question #1. What amp and VDC fuse would I use? my best guess 10 amp 600VDC?
Question #2. Since I would be only running 400 Watts at the moment, would a MPPT Controller be overkill? I was thinking of going to a Tristar 45
Question #3. From the Controller to the battery using probably 6 or 4 awg wire, would a 60 amp fuse be appropriate?
Thanks
Thanks
