Hi guys, new to this forum, my first post. I am performing my first solar installation for my home – will draw the permit myself and will do the installation myself.
My PV specs are:
Total #of panels = 9 -> System DC Power = 9*327W = 2943W. The panels will be arranged in two rows one above another with 4 panels in first row and 5 panels in second row
I want to use SMA 3000TL-US string inverter that has following specs:
My Temperature correction factor = 1.1292
If I wire all 9 panels in series on 1 string, I get DC VMAX = 64.9*9*1.1292 = 660V which is more than the inverters max DC Volt rating. That I cannot do.
If I have two strings: 7 panels in first string, and 2 panels in second string, I get DC VMAX = 64.9*7*1.1292 = 513V than is below Inverters max DC volt rating, but above MPPT operating max voltage of 500V.
Question: what will happen to MMPT if my system gets to 513V on a very cold but sunny day? Will MMPT go to maximum load resistor and that’s it, or will MPPT circuitry will be bypassed completely? Is it wise to exceed MMPT operating max voltage on paper?
My other option is to have 6 panels in first string, and 3 panels in second string, DC VMAX=440V, but that will delay my electricity production start time because my PV system will be operating at lower Voltage.
Thanks, Tomas
My PV specs are:
- Pmax=327W
- IMP= 5.98A
- VMP=54.7V
- VOC=64.9A
- ISC=6.46A
- MAX DC VOLT RATING=600V
- MPPT operating voltage range=125V to 500V
- MAX POWER @ 40C= 3200W
- MAX DC CURRENT=15A
Thanks, Tomas
