48 volt battery charging
or you could just get one 8A4D 200Ah 12V AGM which can handle higher rates of discharge and charging for $380 instead of two 6V batteries.
or an 8A8D 245Ah 12V for $460 :
http://www.batterymart.com/p-12v-245...d-battery.htmlOutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
And those batteries weight over 150 lbs where a 6v 232 Ah battery weighs about 60 lb max. Better get a small fork lift to move those 12volt ones around.or you could just get one 8A4D 200Ah 12V AGM which can handle higher rates of discharge and charging for $380 instead of two 6V batteries.
http://www.batterymart.com/p-12v-245...d-battery.htmlComment
solar panel connections
With my CC set at 12 volt and the 2 6 volt batteries wire in series for 12 volts would the connections be + on one battery and - on the 2 battery?Comment
Yes. You would first connect the - of battery 1 to the + of battery 2. That gets you 12volts between the + of battery 1 and the - of battery 2.
Then connect your charge controller to the + of 1 and - of 2. You would connect your inverter to the same terminals.Comment
panel voltage output
With my 4 panel system, wired in parallel and each panel rated to produces 100 watts and Voc 21.6v and Vop 18v, is the output still going to be Voc 21.6v and Vop 18v and only increasing the watts to 400?Comment
Power and current add in parallel. Parallel is less efficiency and cost more
Power and voltage add in series. Series is more efficient and cost less.MSEE, PEComment
The other half, is the charge controller. under 400w, it's cheaper to use the PWM style (70% efficient). Over 400W, MPPT is the suggested (95%) And if you go series, you will need MPPT to downconvert the 60V from the 4 PV's to 15v for battery charging.Power and current add in parallel. Parallel is less efficiency and cost more
Power and voltage add in series. Series is more efficient and cost less.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I think you meant 200 watts right? I can build a 200 watt MPPT system for less than an equivalent 300 watt PWM system.MSEE, PEComment
Yes but PWM is only 67%. Your 4 battery panels in parallel at best will generate 22 amps. With MPPT I can generate the same current with 280 to 290 watts. Not only that I could use a single much less expensive grid tied panel.
.MSEE, PEComment
