I'm having an 11Kw system installed and supposedly 2 SMA inverters (don't have the exact model # yet). The solar provider/installer is not supplying the web monitoring stuff in the price (ie, not Solar City). I'm purchasing this outright via a SunPower distributor (but not SunPower system, it's LG panels).
Anyway, I'm confused by SMA's website in terms of options.
It looks like you either have Bluetooth or Wired connections, no options for wireless. Also seems like the BT options only go to a PC and no "remote" monitoring per se (ie smart phone) unless you go with the WebConnect box?
I'd like a wireless (ie: 802.11a/b/g/n) setup, but if I absolutely must, I can run Cat5 wiring (just not as easy, mind you). I'd like to be able to monitor the PV system from PC/Smartphones.
Any ideas/suggestions/help?
Thanks!
Kevin
Thanks!
Kevin
