I have a couple of Trina TSM-180D models 72 cells each, and in would like to make each panel into 2 - 18v outputs. As they are setup now (default from factory) they output either 36v, or 3 outputs of 13.7v or 2 outputs of 27v from the 4 ribbons in the connector box on the back of the panels. There 6 rows of 12 cells in 3 strings of 24 cells. My question if I cut the bottom foil to separate the middle row of 24 into 2 rows of 12 cells, will that give me the 18v and 18v I am looking to get from the panels. I am asking first so I don't mess up the panels, if this idea is not possible.
BTW: I am new to photo voltaics if you can't tell.
TIA for any info.
Trina TSM-180D
Peak power 180 Watts
Peak power voltage 36.8 Volts
Peak power current 4.90 Amps
Open circuit voltage 44.2 Volts
Short circuit current 5.40 Amps
Max. system voltage 600 Volts
TIA for any info.
Trina TSM-180D
