Hi, So I'm trying to learn this calculation and I understood most of it but I ran into a problem.
I have a Canadian Solar CS5P 250W Module. The Isc is 5.49A and the maximum fuse rating is 10A. Here's the specs here http://www.enfsolar.com/pv/panel-dat...rystalline/382
So here's the first and second part of the calculation.
Imax = Isc x Number of strings x 125% x 125% = A
I derate = Imax / Correction Factor Temperature x Correction Factor Conduit = B
Imax = 5.49A x 3 x 1.25
I derate = 25.74A / .71 x .80
Even though I completed the calculations, something is off. In the first calculation, my answer is greater than the Max Fuse Rating. Is each string supposed to be less than that fuse? Or am I supposed to have multiple fuses?
Thank you for your help.
