Hi I'm new to solar pv system ownership and this forum but I'd like to pass on some info on a little control system that I've just built to control my immersion heater. I installed a Solar iBoost unit to use excess power to heat water but was torn between staying with the 11" element that was already installed and having a small amount of ready use hot water or installing a longer element and having more water of a lower temperature as background heating to save on gas heating.
In the end I fitted a dual element immersion heater with a manual switch over but this meant keeping an eye on the iBoost to see when it was time to switch over elements. I have now constructed an auto changeover system using a 20amp SPNO / SPNC relay. The relay is switched by the short element thermostat so when the first 16" of water reaches temperature the thermostat breaks the relay feed so the relay drops out switching off the 16" element and switching on the 30" element. I've been testing it today and it works really well. The parts cost about £20. I'm amazed that something like this isn't available commercially but hey for £20 who cares
