I am sure this all may have been asked, i have been unable to find the answers. will a say, 500 watt micro inverter with MPPT still provide MPPT with a 300 watt panel? can panels be wired in series or parallel and hooked to the grid tie micro-inverters ? im sure MPPT would not work but what would its determining value be? Thank you in advance for your patience and help, i am trying to make sure i have a good understanding before making a purchase . best regards b-known
will an over sized micro-inverter still provide MPPT with an undersized panel?
I know of no 500W microinverters
Please provide a manufacturer and model numberNABCEP certified Technical Sales Professional
Google found me the AltEnergy YC-500. It looks like it's essentially two 250W inverters in the same case, since it has two DC inputs with independent MPPT. Here's a link to the data sheet.
Anyone heard of this company before?16x TenK 410W modules + 14x TenK 500W invertersComment
I posted ?s to see if I could get some help, I used 500watt for an example, that is all.Google found me the AltEnergy YC-500. It looks like it's essentially two 250W inverters in the same case, since it has two DC inputs with independent MPPT. Here's a link to the data sheet.
Anyone heard of this company before?Comment
Sorry; I just tend to get really curious about things I haven't heard of before. I apologize for inadvertently trying to push this thread off on a tangent.
I believe the answer to your original question is "Yes," within certain limits. The panel has to provide enough power to power up the microinverter, but once you've passed that threshold it will provide MPPT tracking, though perhaps at slightly reduced efficiency. Others can correct me if I'm wrong.
I believe the usual reason not to buy a microinverter much larger than your panel is because larger inverters are more expensive and it's a waste of money.
So with that out of the way….anyone heard of these AltEnergy guys? And what's the deal with the two-headed microinverter anyway?16x TenK 410W modules + 14x TenK 500W invertersComment
Thanks for the reply, as for the altenergy, i emailed them and asked for a valid phone number, a price list and more company info. If i hear back i will post what i get in return from them.Sorry; I just tend to get really curious about things I haven't heard of before. I apologize for inadvertently trying to push this thread off on a tangent.
So with that out of the way….anyone heard of these AltEnergy guys? And what's the deal with the two-headed microinverter anyway?Comment
The nature of an MPPT input circuit is that it will extract as much power from the panel as is available in the light conditions of the moment.I am sure this all may have been asked, i have been unable to find the answers. will a say, 500 watt micro inverter with MPPT still provide MPPT with a 300 watt panel? can panels be wired in series or parallel and hooked to the grid tie micro-inverters ? im sure MPPT would not work but what would its determining value be? Thank you in advance for your patience and help, i am trying to make sure i have a good understanding before making a purchase . best regards b-known
It cannot tell a 500 watt panel in less than full light from a 300 watt panel in full light.
It will work just fine in getting the maximum power possible out of a 300W panel, but that amount will naturally be 300W or less.
As for putting panels in series or in parallel, you need to start with two panels that have either their Imp or their Vmp within 5% of each other (and same incident light and orientation.)
If the two panels match in Vmp you can put them in parallel. If they match in Imp you can put them in series.
Whether you can actually use one combination or the other depends on what the voltage and current limits of the MPPT input are.Last edited by inetdog; 04-08-2014, 12:37 AM.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Inetdog, thank you for the informnation, i thought that is how it worked but did not want to assume anything, as solar power seems to be confusing with all the little things that have been pointed out to me.The nature of an MPPT input circuit is that it will extract as much power from the panel as is available in the light conditions of the moment.
Whether you can actually use one combination or the other depends on what the voltage and current limits of the MPPT input are.Comment
I have gotten a reply from the altenergy company (no price list, but i requested it again)Sorry; I just tend to get really curious about things I haven't heard of before. I apologize for inadvertently trying to push this thread off on a tangent.
If anyone is still interested in the information that they have sent to me i would be happy to post it for you. or can forward the complete email to you if you would like..Comment
It would be interesting.[SIGPIC][/SIGPIC]Comment
Thank you for your interest and attention to APS Micro-inverter!
APS datasheet is enclosed for you.
YC500 is best seller in the world.
How many units do you need?
Where are you from?
Have a nice day!
Sophia
logo1
Sophia Yang
Sales Manager
Altenergy Power System Inc.
Add: Rm.B403 No.188,Zhangyang Rd,Pudong,Shanghai 200120,China
Website: www.solaraps.com ; //www.altenergy-power.com
Tel: +86-21-33928205 ext 8016 Fax: +86-21-33928752
Mobile: +86-13636626163
Skype: sophiayangf
E-mail: sophia.yang@altenergy-power.comAttached FilesComment
I hope i posted it correctly, can i get someone to confirm that it posted with the attached pdf correctly plz? I am still learning how to use this forum thanks..Comment
