Silly Question- 12V or 24V system
No, if you have 4 12volts 100amps hours, you have 400 AHs, if you connected 2x2 you have 2 times 200ahs =400 ahs, if you connect 4 in series you have 4 times 100amps = 400 ahs. if you connect them 4 time 100amps in parallel you still = 400 ahs.
The total amp hours in a battery bank don't change just like total watt hours.Comment
Connecting in Series
When connecting your batteries in Series you are doubling the voltage while maintaining the same capacity rating (amp hours). This might be used in a scooter, Power Wheels kids vehicle, or other applications. Just use a jumper wire between the negative of the first battery and the positive of the second battery. Run your negative wire off of the open connector from the first battery and your positive off of the open connector on your second battery.
Connecting in Parallel
When connecting in Parallel you are doubling the capacity (amp hours) of the battery while maintaining the voltage of one of the individual batteries. This would be used in applications such as laptop batteries, some scooters, some ups backups, etc. Use a jumper wire between the positives of both batteries and another jumper wire between the negatives of both batteries. Connect your positive and negative wires to the same battery to run to your application.
Connecting Batteries in Series or ParallelComment
Your contradicting yourself...Comment
Sorry Paul, you're statement is incorrect.
As I am new and am leaving the boxing gloves offI just want the correct information. Thank You! Now back to the task at hand. What are some good Inverter options? Names? 24V of course .
Oh and the poster that said 6v golf car batteries a few post up. I would love to but costco doesnt show that they carry it or what kind of price it should be.Comment
