Hi All,
This is my first post in the Community and I hope someone can shed some light for me as I'm new to the solar game. I have purchased and installed 6 - 180 watt panels (24V 7.7 amp) and have tied them in parallel with each other. (I have also tried series with two panels) The systems longest run is 20 feet back to the bus bar. I'm using 10 gauge wire and the bus bar is rated for 100 amps. I have connected the system to various inverters a 600 watt MPPT and a 1200 watt MPPT grid tie inverters. The 600 watt unit will produce about 400 watts from the 1000 watt system and the 1200 watt inverter does 250 watts. I have another small test system with two 180 panels and they are producing 260 watts with a 300 watt inverter. I guess my question is What can be going wrong that I'm only getting 40% of the rated output? I realize about transformation losses but the book on the inverters say they are 92% efficient. I have measured the output open circuit and they panels are doing what they are rated. Any ideas?
By the way this is a grid tie system. I also have pictures if anyone is interested.
