(by the way i'm new here and I really appreciate this forum. thanks to those who answer questions... i have quite a bit of experience in solar and I'll definitely put my time in too)
i am putting together a system that requires a ground mount.
A seasonal adjustment of tilt angle will give up to 15% output year round, so you'd think that most of the ground mounts would have this option
but i can't seem to find any that are made to hold these new bigger panels and also have adjustable tilt angle.
Unirac's Solar Mount Tilt doesn't have adjustments.
DPW's adjustable mounts are only for the smaller solar panels.
Prosolar's aren't adjustable.
So then I look at top of pole mounts, which are adjustable. But only because you can loosen the ubolt that is holding the structure to the pole, adjust, and retighten. I think after making seasonal adjustments the nuts and ubolts will wear out, and that ubolt is the main thing holding the panels in position on a round object. (think how much easier it is to hold a square object in position than it is a round object). after a while it's going to be hard to tighten it as much. then when a 50 mph wind comes I'd start to worry about my panels.
DPW also has the multi-pole mounts which seem kind of cool (less stress on each pole/ubolt) but it's the still the same thing with the ubolts.
So I guess people just don't do seasonal adjustments anymore, now that the arrays have gotten a little larger? kind of sad...
So a couple questions...
are there any adjustable ground mounts I'm missing that can handle a dozen or 16 200W panels?
and
if I spec a top of pole mount, are people really loosening and tightening that ubolt all the time and not compromising the strenght of the connection?
thanks
gary a.k.a. the solar bus guy
and
thanks
