I am installing my own system. It was a package deal so you would think it would be plug-n-play but after everything
was installed I started to hook up the solar panels to the SolarEdge "power optimizers" and the output leads from the
solar panel that need to connect to the input leads on the power optimizers are the same fittings i.e. male to male and
female to female.
Does anyone know if it is fairly easy or straightforward to swap the cables coming from the little j-box under the panel?
Is there an adapter that can go from male to female and vice versa?
Thanks
Here is a picture of what I mean.
female to female.
Thanks
