I am travelling to Haiti to install a PV system in a remote area and there is concern that the modules will be stolen. I am looking at using security screws, for both lagging into the roof and also for mounting the modules and building the mounting structure. so I'll need both lag screws and nut/bolts. Both the nuts and bolts will have to be tamperproof. Stainless steel. I came across this website that seems to offer a wide variety http://tamperproof.com does anyone out there have experience with this? any recommendations? please let me know --gary
Looking for recommendations re: security screws for mounting hardware (for Haiti)
I get asked about these a fair amount and have always recommended Bryce:
Leading Manufacturer of Custom Tamper Proof Screws, Tamper Resistant Security Bolts, Vandal Resistant Nuts, Anti Theft High Security Screws, Locking Nuts & Security Fasteners. You may contact Bryce Fastener today at (480) 503-3801 with any questions or to request a custom project.
Your mileage may vary, good luck!Committed to the support of renewable energy. -
Chris I see you are in Stowe? I'm right around the corner in Richmond!remI get asked about these a fair amount and have always recommended Bryce: http://www.brycefastener.com/ Your mileage may vary, good luck!Driver of the Solar BusComment
Small world! I'm actually even closer, living in Waterbury these days.Committed to the support of renewable energy.Comment
Thanks Mike that really helps... especially since I already have a McMaster account.
one question.... I'm thinking I need to put security nuts on the modules too. my issue is, whichever I put on the inside of the module frame (facing in towards the front of the module) there is very little clearance there and how am I going to get that fancy tool in there to tighten things up? I've always used a standard wrench to hold the nut in place while I tighten the head of the bolt with a socket wrench. with these security screws and nuts I'm not sure how I can reach in behind with the tool and get the job done. any ideas?Driver of the Solar BusComment
Well, only one side need to be security, other side can be plain. Make it tough enough, the vandals will jsut smash them
Or get a dingo, and feed it very little.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
