We are installing a 10.5 Kw solar PV system on a residence. The inverter requires a 60 amp breaker. My main panel is 200, and I cannot find information about the busbar rating. My understanding is that I can only use a 40 amp breaker (20% of 200) unless the busbar is rated higher than 200. If there is no spec sheet, how can I find out if the busbar is rated higher than 200?
Any suggestions?
Any suggestions?
