I have a grid tie solar application in which one panel has been broken. I need to replace the one panel.
The original specs were:
2 strings of 11 panels (22 total) 230 watt nominal power at STC, Vmp 29.6 volts, Imp 7.78 amps, Isc 8.34 amps
The closest match I have found has the following specs:
225 watt nominal power at STC, VMP 29.4 volts, Imp 7.65 A, Isc 8.19 amps
Now, if I replace one panel in one of the two strings, will the mismatch of 0.6 volts/0.13 amps matter?
