Inverter question - DC inputs vs Strings?
  • themightykc
    • Aug 2011
    • 3
    Dear all,
    I am a little confused regarding DC inputs on inverters and strings that an inverter can take. For example, I have a Fronius IG 3.6 here which has 6 DC inputs, but does that mean I would be able to run 6 different strings to combat shading problems? From my understanding, 6 strings would allow me to have 6 arrays on 6 different roof aspects, is that correct? Or does somebody have a good website describing strings and the DC input differences?
    Help would be much appreciated.
    A
    The keyword to look for , is Independent MPPT , otherwise, they are just parallel terminals. (you can verify with ohm meter before you connect any power, or connect 1 array, and try to measure voltage on the other 5. I think you will discover they are "combiners" and not independent.)
    I know of no controller with 6 MPPT channels. I've heard there is one with 2 MPPT channels.
    • themightykc
      • Aug 2011
      • 3
      Thanks Mike,
      Just had a look at an SMA SB 2500 HF and the inverter itself has 1 MPPT tracker but 2 strings. Is that possible? And if so, could I have the solar modules on two different roof aspects and how would this affect shading? (sorry for all the questions!)
      Cheers,
      A
        Each MPPT tracker, can only manage cells/panels that are the same, and aimed in the same direction. If you mix arrays, it will "hunt" between them, with less than good results. Just having 2 or more sets of screw terminals, does not make MPPT magic happen.
        • themightykc
          • Aug 2011
          • 3
          Cheers Mike,
          Thanks for the help, much appreciated.
          A
