How to string: series of panels to junction to disconnect to + and - generator ports.
  • PaulaK
    • Oct 2025
    4 panels in series. With the female mc4 end of the end panel which they diagram as - will get the black pv cable (male mc4) to the junction box. Then a wago black connection to be "threaded" to an inside disconnect. The black negative cable that goes into the disconnect has a male mc4. So I put a female mc4 on the end of the black cable that ran from the junction box. out of the disconnect black is a female mc4. so I put a male mc4 into this and the end I put a female mc4 and stick it in the male negative port on my generator?
    Panel -female, black cable male to junction box, wago nut, conduit to house, female mc4 crimped onto the end, into the disconnect black (-) male mc4, out diconeected mc4 is female. Make a cable with male into this and female on the opposite end that goes into the male (-) negative generator port inlet plug.
  • ZhangSheng
    • Nov 2026
    Good point to check the whole run, not just the connectors. A few things that help on a string like this:
    - Fit a grommet or bushing wherever the PV cable passes through the junction box, disconnect or any metal enclosure, and deburr the hole first so the edge cannot cut into the insulation.
    - Keep the cable off sharp tray and enclosure edges, and respect the cable maker's minimum bend radius at the MC4 and box entries - a tight bend is a common place for insulation to crack later.
    - Where the cable can rub or vibrate, add an abrasion wrap with about 50% overlap, and secure it so it cannot slide and leave a bare spot.
    - Leave a small service loop at the junction box and disconnect so the cable is not pulled tight, and support the run so its weight is not hanging on the connectors.
    - For any outdoor exposed section, inspect it periodically for UV-brittled or chalky insulation, and replace a damaged section rather than taping over cracked insulation.
