Parallel or series parallel
  • asdex
    • Nov 2013
    • 174
    Hi, if I connect my new panels in parallel I get max outputs of around 40 amp and 45 volts.
    If I connect series/parallel I get 20 amps and 96 volts.
    My controller is rated max of 50 amps and 150 volts.
    Which option would be best. Its a 24 volt system.
    Cheers,
    Using a PWN controller, I'd opt for panels in parallel. You might need to use 2 controllers, with half the panels on each controller. Gives you a bit of redundancy.
    Panels in series, I'd limit it to just two in series, a MPPT controller has to work harder to convert high PV voltage to lower battery voltage.
    Do you know what kind of controller you have ?
    • asdex
      • Nov 2013
      • 174
      Thanks, yes it's an Epever Tracer 5415AN
        Is that a PWM or a MPPT controller ?
        • asdex
          • Nov 2013
          • 174
          It's a Mppt controller.
            OK, if it's MPPT, you want to run just 2 panels in series. How many panels do you have ? The controller should limit itself to 50A, and if you have 55A available, it should be able to handle a
            small amount of overpaneling without a problem.
            • asdex
              • Nov 2013
              • 174
              I have four 360 watt panels. Max o/c voltage 47.4v. Max current 9.24A.
              Thanks
                1440w of panels, derate 20% = 1152 realistic watts @ 26V = 44.3A expected output under reasonable conditions.
                2 panels in series, and paralleled with the pair of panels in series, is likely your best bet
                • asdex
                  • Nov 2013
                  • 174
                  Great, thanks very much.
                  • asdex
                    • Nov 2013
                    • 174
                    So would be the controller input be 96 volts and 20 amps? So two panels in series 47.4v x 2 in both sets of panels in series and 9.24A x 2 for the panels in parallel.
                      Yes. MPPT chargers are rated at output amps ( you said yours was 50A )
                      • asdex
                        • Nov 2013
                        • 174
                        Great, I Didn't know that.
                        Thanks
