Just had these panels installed and noticed nearly all of them have white spots on them. Anyone have any insight of this is normal or what they could be?
are spots normal?
THink my pictures were too large at first...here's a sample. If you look at the panels, it almost appears that the white spots are in the same spot on each of the panels affected (though some are upside down). I'm still waiting to hear from the installer but wanted to reach out to the community for additional insight.Attached FilesComment
It may be possible that how they were stacked could have caused a blemish or worse a weak point on those panels.THink my pictures were too large at first...here's a sample. If you look at the panels, it almost appears that the white spots are in the same spot on each of the panels affected (though some are upside down). I'm still waiting to hear from the installer but wanted to reach out to the community for additional insight.Comment
Thanks for the picture. No, they are not normal. Have you tried wiping those spots to see if they are just something that comes off easily. They seem to be consistent in location so I would rule out bird poop. As SunEagle , said maybe it is how they were stacked.. If you can't reach from a ladder try a jet of water early in morning or early evening when panels are cool, If you have panel level information can you tell if it is affecting output?Last edited by Ampster; 04-09-2021, 03:25 PM.9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
something un-good has happened to them, sadlyPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I've never seen spots like that. And I've seen many thousands of panels. Its almost as if one of the robotic handlers at the factory had a problem and smeared something on that spot. I can say that the glass used in PV panels has an anti-reflection texture to it. If you drag one panel's aluminum frame on another panel's glass, it leaves a smear of aluminum in that texture that does not easily come off. What brand are these panels?
Another possibility is there are plenty of substandard "B"-grade panels out there that have "cosmetic" flaws and are sold way cheap.BSEE, R11, NABCEP, Chevy BoltEV, >3000kW installedComment
They are Hanwah Q Cells....The installer said they would return to see if the spots can be removed.....as far as panel level information goes, I'm also still waiting for the installer to provide the credentials to be able to monitor performance.
TO be continued....Comment
