DIY Combiner Box
As you stated the QO breakers are rated at 48Vdc so is not suitable for most off grid arrays feeding any modern charge controller that goes up to 150Vdc (or more). It is such an advantage to get the string voltage up as high as the charge controller will allow, that hamstringing your array with a 48Vdc combiner doesn't make sense to me. Going with 200Vdc+ strings for a Midnite Classic200 for example allows you to run as many as 6 panels in a string and up to twelve panels before even needing a combiner.BSEE, R11, NABCEP, Chevy BoltEV, >3000kW installed -
@solarix That is true, good point. I probably should have emphasized that more in the video.
But the majority of off grid solar applications do not go above 48V. I guess I should have posted this in a different sub-forum because you are right, homeowners off the grid will be using higher voltage to power an entire home with long cable runs. This DIY build is for everyone else that is using them for RV's, boats, sheds, workshops, job sites, SCADA, surveillance cameras, and other smaller off grid installations.Comment
Once someone is using over a 1kw inverter, stepping up to the next voltage (24v) makes more sense then bunches of parallel batteries and super heavy fat cablesPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I like the video. Have built many of my own combiner boxes. All I would add is that the Midnite or Outback dc breakers are very competitively priced, making the need to use QO or QOU breakers with their relatively low dc rating unnecessary. You may need to use din rails in the enclosure though.2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
Also, sometimes DC breakers have a "polarity" of which direction the current flow goes, and their internal arc suppression works best in, You may see a + on one of the terminals.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I am wondering if you actually plan to physically open a conducting breaker? That
is something to only be done in an emergency for my 400VDC grid tie system. If
not, DIN mounted fuse holders can be used, and can be used to break the circuit
manually when the sun is down as well.
The Evil Bay fuse holders I ordered were economical, and I asked them to put in
the proper size fuse, no extra charge. Bruce RoeComment
As soon as the panels have build in blocking diode and they are fused and grounded appropriately, what else is nessacery for safe use?Comment
Most panels, do NOT have a blocking diode, that task is usually handled by modern Charge Controllers.
Many panels contain several BYPASS diodes, that allow a partially shaded panel to pass electricity thru it, instead of totally stopping the electricity
