I’m putting together 38 jkm335ma60hl, 10kw growatt, tigo optimizer duo, the east will have 2 strings, 8 stringed & a string of 9. south will be 3 strings of 7 branched together for the 3rd string. the 3rd string is 19A, 6500w, I’m concerned with the string having to much amperage, but I believe the optimizers will detect the 19A limitation and adapt? my knowledge of branching/optimizers is limited, design must be nec2014, the first string connection appears to show two positive and two negative in the manual, but could not be certain, and help is appreciated
Panels
https://tandem-solar-systems.com/buy...-solar-module/
Growatt data sheet
https://www.growatt-america.com/uplo...ea6737869a.pdf
Growatt manual
https://www.growatt-america.com/uplo...ea98ac4afa.pdf
Tigo optimizers
https://files.sma.de/downloads/SMATS...838-V13web.pdf
Panels
Growatt data sheet
Growatt manual
Tigo optimizers
