I've doing a ground-mount of a 4x4 array of 39x65" panels in landscape orientation.    I'll use two pairs of 14ft IronRidge XR1000 rails (supported by wooden girders at each end), at a 26degree angle.  The panels will be attached to the rails using IronRidge's little "UFO" clamps; each rail has a clamp at each end, and a clamp between two adjacent panels.
My question: What is the best sequence for mounting the panels ? I'm worried about even being able to reach the clamps on some of the panels. Looks like maybe professional installers have special ladders that lay across the panels without damaging them; dunno if I can manage without that, or if I can improvise.
If I can mount each row starting at the high (north) side and working downwards, I imagine I can easily lean over the 3ft dimension of the panel to reach the upper UFO. But that means tightening the clamp at the high side all the way (since I won't be able to reach it later); hopefully that is tight enough that the panel doesn't slide downwards, and also requires that tightening the clamps along one edge of the panel, without any clamp at the other edge, does not deform the panel. Alternatively, I could work upwards; that would eliminate the sliding problem; but leaning over that 3ft extent, while the panel is sloping down away from me (about 20", I made the angle be the arc-tangent of 0.5 for simplicity of framing the wood), will be a lot harder, if not impossible, than working downwards.
Anyhow, obviously I have no clue how to do this.
