Hi – I have a ground mount system that will have two arrays, and four strings.
I also have two inverters – each with 2 MPPTs
Because of the inverter(s) voltage limitations - I need to use all 4MPPT’s - one per string.
My question - based on my research, I will need to run a positive and negative per string in the conduit all the way back to the inverters plus a ground - for a total of nine wires. Can someone please confirm that this is accurate?
thank you so much and please let me know if you have any questions
Steve
Steve
