So I have been pretty busy and obsessing about going solar for a few years and am finally in a position to (hopefully) get it done. I have been doing as much reading and research as I can but there are a few "holes" in my understanding that I hope you guys could help with. As much as I have gone round and round I am fairly certain I want to do IQ7 micros with 325 watt Hanwha q cells. Seems to be great pricing on these locally. I do have a small amount of shading and will likely have a bit more over the next few years from regrowth of some large Oaks ( we got hit bad by hurricane Michael).
Q1: I can't seem to find a whole lot about info on bringing the Enphase q cable into the J-Box and what those connections look like. Does anybody have pics or links to what that looks like? I intend to hire an electrician to do the more technical parts but am wanting to know for my own understanding.
Q2: I will have three arrays on two different roof levels. I was wanting to know if I could bring a home run cable from arrays B & C (see attached pictures) to a j box in the attic under array A. Then bring The q cable/conductor from Array A to that same J Box and combine it there for a single line back to the electrical panel. Is this advisable and best practice or should I run as second separate conductor and ground wire in the same conduit to the combiner/Envoy? I really want a clean look and don't want to run exterior conduit if I don't have to.
Q3: I have two main electrical panels with a 200 amp main breakers on each. How do I know if I have the available room for 3 branches with the 20 amp breakers required? I've attached pics. Not sure how this quite works because there are open "slots" for extra breakers but when I add up the total amount of amperage on the existing breakers it comes out to 280 +/- on each panel. I would also like to know if I could potentially add a NEMA 14-50 in the future if we were to go electric.
I welcome any other thoughts/advice based on my pics too.
Thanks so much, I know I have others but those are some of the most nagging.
