Hi there!
I'd like to maximise the usage of my single roof area by mounting as many solar panels as possible on it. I can fit 6 rows with 9 panels mounted in landscape orientation. That gives me three strings with 18 solar panels in each string. Not so bad.
Now, I have the option to fit three more panels in portrait orientation. That is, to each existing string with 18 landscape oriented panels i can attach a single portrait oriented panel giving me 19 solar panels in each string. The additional panels will of course be mounted to the same rectangular roof area (parallell to the roof).
However, lately I have been thinking that it might be a bad idea to go ahead with adding the 19th portrait oriented panel... What if the both panel orientations (portratit vs landscape) doesn't always yield the same voltage/power at any arbitrary solar angle? Another way to put it, can a solar panel be spun like a fortune wheel without varying the power output? If not I guess I should avoid adding the 19th differently oriented panel to the strings.
I might not always be good in explaing things... can my question be understood?
Thanks in advance for any help!
Cheers!
Cheers!
